title-content
AIR PRODUCT
subtitle-content
Which Home Cooling System Is Right for You?
With summer just around the corner, it's time to fire up your Hisense portable or window air conditioner and enjoy some refreshing, cool air. Before you do, follow these simple maintenance tips to ensure your AC stays in peak condition.
Clean The Air Filter Like A Pro
Hisense air conditioners feature reusable filters that are incredibly easy to clean. Simply open the filter panel, remove the filter, and either vacuum it or wash it with mild soap and warm water. Ensure the filter is completely dry before reinserting it for optimal performance.
Don't Let Drainage Issues Rain On Your Parade (Portable ACs Only)
Your Hisense portable air conditioner is designed to efficiently remove moisture from the air. To drain your unit, follow these steps:
  1. Power Off: Unplug the unit or disconnect the power.
  2. Relocate: Move the unit to a location where it can be safely drained, such as near a drain or outside.
  3. Drain: Remove the primary drain cover and plug, allowing the water to drain completely.
  4. Reassemble: Once the water is fully drained, replace the drain plug and cover.
If you’re using a Hisense window air conditioner, you can skip this process as it does not require manual draining.
Keep That Airflow Flowing
To make sure your Hisense AC works its best, keep the area around it clear. Move any furniture, curtains, or other items that might obstruct the airflow. This simple step will help your Hisense air conditioner keep you cool and comfortable all summer long.
At Hisense, we are committed to providing you with a cooler and more comfortable environment with our best-in-class air conditioning solutions. By following these easy at-home maintenance tips, you'll keep your Hisense portable or window air conditioner running smoothly for years to come.
title
Recent Press Releases
page-size
9
data-source
/us/en/blog.json
empty-text
NO RESULT
